2 members (Hotrod Lincoln, Gdads51), 76 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#774176 08/23/2011 4:23 AM
Our 3100 didn't come with any shift linkage rods, now we have them but are pulling out our hair figuring out how they mount. Does anyone have any pictures of them from the column to the tranny. Searched the web computerdeath and the Bolt and came up empty.
Thanks in advance.
....David
How many rods do you have?
What year truck did they come off of? Earlier years used fewer rods tan used in 1954.
Do you have the pivot pin on the clutch housing?
Do you have the attachment-bracket (bell crank) that goes on on pivot pin on the clutch housing?
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0702.html
we have 3 rods, one rod is "full legth" the other is a 2 pc with a bent metal cam thingy (attachment bracket??) that mounts to the bell housing pin, No pivot pin on our bell housing, but we could fab something up if needed. I think this one may be from a 50-51 - ours is a 54. Thanks for the info Tim.
....David
The 3-rod set is for pre-1954 3-speed linkages. Those rods are made to work with the pivot on the pre-54 clutch housing.
My guess is that you will not get those rods and bell-crank to work properly on your 1954 truck.
