1 members (ShopRag),
63
Mod | | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 20 New Guy | | New Guy Joined: Mar 2009 Posts: 20 | I've finally got around to get started on the 57' again. I made room in the driveway for it so time to get working on the engine. The can turn the crankshaft about halfway then it stops so it looks like I'm going to have to take it apart and rebuild it. I should get started on it this weekend. Its slow going for me cause I work at night and watch my daughter during the day so I only get to work on it on the weekends. | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Hey Joe I am working toward restarting my own project. One thing I have to ask is this, did you try to rotate your engine with the spark plugs in or out? I would try it with them pulled out. It may not change anything but it might. I think it is worth a shot. If your plans have included a rebuild of the engine then I think you have nothing to lose. Good Luck
Brian
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
