3 members (J Lucas, Wally / Montana, Wickedbass), 109 guests, and 0 robots.
Topics128,075
Posts1,055,916
Members48,429
#773950 08/22/2011 5:35 PM
hey all, i recently thought it would be a "great" idea to upgrade/replace my stock intake manifold on my 235 w/ a offy 3x1 w/ 3 matched 1bbl rochester carbs. i got a great deal on the intake w/ carbs (120 bucks), so i felt i couldn't pass it up. the only thing missing was the linkage which i am finding now to be nightmare to find. i would like a progressive set-up, but if not straight linkage will do. does any one have any info on this? trying to find this stuff online or on the phone is a full time job in it self. any info is greatly appreciated. thank you -DVZ
You may want to contact the Inliners website and ask around over there. A lot of those guys are into street rods, racing etc. and often have a better handle on things like this than we do. A word of caution however is to be careful of the linkage/firewall clearance problems so often encountered with 3-6 cab setups.
Also try Larrowe & Sons near Sandy, (Portland) OR @ 503-668-0352. Good Luck.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Langdon's has a three carb linkage check his website
50' chevy 3100 shortbed
thanks for the replies guys. i went to langdons and he said he only had linkage for a 250, but it has about 95% of what i need. i just went ahead and orderd 2 double carb linkages from summit. i will make it work. thanks again guys -DVZ
