| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | I have read on the forum that 73-87 fromt crossmembers will fit under a 65 C10. What about a 71 C10 to the 65? Will it work? pros & Cons?
Thank you | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | It will work as well. If I recall the difference is the ball joints.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
