| | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 4 New Guy | | New Guy Joined: Aug 2011 Posts: 4 | After your guys help with the cross member swap. I have been eye ballin the crew cab trucks I understand they were coachbuilt has anyone on here built one. I.have a 61 gmc 1000. I was thinking of a later model 63 4. Cab for the rear donor are the profiles the same? What have you guys done for a chassis. Thanks for any help | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I never did one. But i was thinking about an extended cab for a while. I had a 94 extended cab truck that would have worked pretty well. I suggest taking a tape measure out and start checking some wheelbases out. When you say, 63/4, what do you mean. The 63 cab is different than the 64 at the windshield. I would imagine that 2 cabs would be the normal way to go. With the roof panel being the hardest part. However if you have a scrap 'burb around, I think that might be the easier way to get the roof right. Check the gallery for crewcabs and PM those guys. | | |
