| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I was just on Classictruck.com and saw that they had a roller bearing for the 3/4 and 1 ton spindles. It was the first time I have ever seen anything other than the ball bearing type. Has anyone else seen this too? Anyone used them? | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | What year? I have them on my 1941 1 Ton. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've seen the listings in a couple of the vendors catalogs | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | They have them for 47 to 52 and 53 to 59. It's the first I've seen them for the 3/4 and 1 ton. They are extremely pricey, but what do you expect for a 60 year old truck? It would be nice if they were a good brand like Timken, but I'm sure they're Asian made. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I have 2 sets of these waiting for installation on a couple of projects. The are made in Japan by a company that appears to make a lot obsolete bearings. MBS bearing - Japan
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Do they look like pretty good quality? | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | They look just like any other bearings I've had experience with.
Based on my experience buying an 18" caliper a couple of years ago, the stuff made in Japan is just as expensive as the stuff made here. I took that as a sign of pretty much equal quality.
