| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 9 New Guy | | New Guy Joined: Jun 2009 Posts: 9 | Hi Guys
I'm having trouble ordering hubcaps for my 58' Chevy with 8lug differentials,
Can anyone direct me to a site where you can order these, the LMC site is not that clear for what truck the caps are for.
I live in Namibia and returning parts can be problematic.
I have a 58chevy pickup step side longed. With 8lug rims or floating differentials at the back
Christo
C Loubser
43 Ford CMP 4x4 48 Ford F1 41 CCKW 2 1/2 ton GMC 6x6 57 Land Rover series 1 59 Mercedes 220s
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | They are not being reproduced to my knowledge. I looked for them for my '59 3/4 ton (8 lugs)and I could only find a few beat up and rusty originals. I went with new aluminum wheels. I've seen a few on Ebay from time to time but none in good shape. All I can say is GOOD LUCK! | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | What's the issue? The hub sticks out too far or the diameter of the clips? If it is the hub, then just have a machine shop cut a hole in reproduction caps. If it is the diameter of the clips, then I don't have an answer.
I bet your truck gets a lot of attention in Namibia! | | | | | Joined: Jun 2009 Posts: 9 New Guy | | New Guy Joined: Jun 2009 Posts: 9 | Well at the moment both is standing, restoring one converting the other.
How would you go about machining those hubcaps.
C Loubser
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | My take is jomichael is talking about cutting a hole in the center of the hub cap so the hub can poke thru it Christo. That would work to cover up the nuts but not the best answer if restoration is your goal.
The Filling Station lists 1957-60 3/4 & 1 ton truck part number L-315. Take a breath now, $70 each/$240 set of 4.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Ouch on price! That hole is looking pretty nice, huh? That's what the factory did with the front hub caps on NAPCO 4x4's.
