| | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77382 05/10/2007 5:17 AM | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | How can i tell if the correct oil dipstick is in my 50 model chevy it looks like there is a quarter inch or less gap between the stick seating and the top of the tube that it goes into,the stick remains exposed about quarter inch, the handle appears to have been resoldered onto the stick, is there a length spec somewhere of this dipstick so i can get replacment on 216, i also wonder if maybe a grommet or seal is supposed to be there to fill the gap thanks Ken | | |
#77383 05/10/2007 1:52 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The tube sticks out of block 6". The OA length of the dipstick from the stop washer to the bottom end is 15 3/32". The FULL mark is 13 3/8" from the stop washer. The ADD mark is 13 7/8" from the stop washer. Don't know if there is supposed to be a felt/leather/fiber washer under the stop washer, mine has none. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#77384 05/11/2007 5:22 AM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Same question for a 1954 235. How far is it from the cap/retainer to the full mark. How far from the full mark to the fill mark?
My truck came sans dipstick.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
#77385 05/11/2007 6:15 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The stock pan holds 5 quarts. Just put 4 in, then you have your quart low mark, and put in another, and you have your full mark.
#77386 05/12/2007 6:11 AM | Joined: Apr 2007 Posts: 44 Member | | Member Joined: Apr 2007 Posts: 44 | Thanks all for the replys mine has the side mounted oil filter should it be 5 or 6 qts | | |
