4 members (55shaker, Gdads51, 1955 1 Series, 1 invisible), 122 guests, and 3 robots.
Topics128,070
Posts1,055,900
Members48,429
#77376 05/10/2007 3:17 AM
i have a 12 bolt posi from a 71 chevy 1/2 ton truck in a 66 carryall, the problem with it is a chatter when i turn left ,after it has been driven several miles {say 150 miles or good and warmed up?}right turns seem to be ok? can new clutch plates be bought at gm or? and should that cure the problem ? i have not torn it apart yet to inspect the plates ?what should i look for on used plates ? thanks mike
Currently cruising
in the
Passing Lane
#77377 05/10/2007 3:50 AM
I'm not an expert on these rears, but my first thought is that you need to make sure it has the right gear lube and additive in it.
Are you sure its the right stuff? If not that's the first thing I would look at.
Second thought is that those clutch plates are a wear item and the amount of trouble rebuilding a rear represents, I'd think it would make more sense to look hard for new parts first.
#77378 05/10/2007 2:02 PM
First thing we always did at the shop was drain & refill the diff w/proper lube using the GM additive, then find a parking lot & drive in figure 8's for a while to work the lube into the clutches. I'd say at least 50% time it worked. If no difference at all, tear into it.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#77379 05/10/2007 8:49 PM
The type of rear end with the tapered cone clutches MUST have the additive in it. The clutch-pack types will work with regular gear lube. It won't hurt to add the stuff the dealer sells to either type of rear end, but without it, you'll have nothing but grief from cone clutches. Try a drain & refill with GM limited slip additive before doing anything else.
#77380 05/11/2007 12:17 AM
thanks for the replys ,i guess i should of said in the first post that i have already done the gm oil,and additive plus the figure 8S all with no help it still had a chatter after about 60-80 miles on a left turn!plus we tried an extra bottle of additive per an old gm mechanic ! so i believe i had better tear it apart ,any ideas on tearing it apart? i think all needed is to remove crosspin and gears and pull clutches ? been a long time ?thanks mike
Currently cruising
in the
Passing Lane
#77381 05/11/2007 8:44 PM
My Chevelle had the clutch type and was very lube finicky. Had to add the additive the lubes that said they work for limited slip diffs didn't.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
