0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#773642 08/21/2011 7:01 PM
Got a 46 1/2 ton, Just want to replace and need to align headlights. I was thinking 20 ft to a wall, measure height and width of the lights and adjust accordingly. Is this about right?
Rick.....
That's as good a way as any, just adjust the high beams so the "hot spot" of the beam is level with the headlight height and more or less "straight ahead". The prism in the lens will drop the low beam down and right. There's a special alignment fixture we used to use that clips onto the three little studs built into a sealed beam bulb, but I haven't seen one of those systems in use in years.
Riding in the Passing Lane
I still have one of the Hoppy adjusteing systems. If you get to K.C. I will do them for you. It doesn't work on the later models with the new type headlights.
1972 Chevy c10 Cheyenne Super
the shop manual has the details
I'll take you up on that, George. I looked all over town for someone to set mine before using the shop manual method on the shop door.
Ex Hall Monitor
Ex Hall Monitor
You are comeing to the reunion arn't you? I will bring the kit with me & we will find a level place & adjust them.
George
Go to :
www.danielsternlighting.com/tech/aim/aim.html
Very specific, very easy to follow and works like a champ. Very happy with the result.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
