| | | Forums66 Topics128,115 Posts1,056,623 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Does anyone have their Passenger door lock removed so that they could send/post a detailed picture/s of what the flat steel retaining clip looks like, preferably with a scale visible? Had carefully kept mine on disassembly and now need it and can't find it, will have to make one I guess.
Or if anyone has an extra, . . . . .
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Oh man... I just put mine together Saturday but did not take a pic. I also can't find my re-plated tee handle for door lock on drivers side. I can tell you the clip is not flat but has a bow in it spring tension. You put the retainer in part way or enough to slide the cylinder lock in from the side of door, once the cylinder is in place push the clip in to lock in place. | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Green Farmer, Sent you a P M.
