| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | I've just finished my wood for stake bed. 2 coats of stain and 9 coats of Minwax Helmsman Spar Urathane. Does anyone know if I should wax after final urathane coat or not? The clear gloss looks great. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i put six coats of the same thing you used on my flatbed. after it had fully dried i waxed mine along with the freshly painted bed frame. since i didnt want to scratch it all up right away when i was loading my travel box for the south bend trip. i decided to take my shoes off and climb up there to load the box. i almost broke my neck when i slipped on the surface, slicker than ice. it looks super shined with a coat of wax on it and beads up well when it gets wet. just be careful up there with no shoes on or when its wet. | | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | Thanks for the reply, can you tell me what you waxed with? Has it all held up good to the weather?
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i used rain dance and any wax will work. if your taling about the bed finish itself so far yes but then its garaged kept and only get wet when i wash it of i get caught out in the rain while im at a show. | | |
