| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | I have a couple questions as to which oils/fluids to use.
Transmission oil.... is there any specific type i should use? and where do i fill it? ive seen pics on a couple trucks that have a spout leading to the transmission but mine doesn't.
Diff fluid... Im not sure if my problem is that i have no fluid left, but when i was doing my brakes i noticed a "ticking" noise come from the differential every time the rear wheels were spun, same for the front.
Steering box, it has a "ticking" noise just like the rear diff when the steering wheel is turned, im not sure if this is the issue i have with the front wheels ticking or if its just the steering box
Any suggestions on what i should use? or even maybe my problem isnt low fluid/oil but just a bunked up part? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, you could use 80-90 wt. for all three of those applications, after you fill watch for leaks from everything. The transmission fills through a plug on the side of the case. about a third of the way up the side, fill to the bottom of the threads. The diff. fills through a plug in the rear of the housing (actually a cover), fill to the bottom of the threads. The steering box fills through a plug in the top of the housing, there has been a lot of discussion about using John Deere corn head grease in the steering box as it is obviously less likely to leak out, hope that helps. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You should not have a ticking noise coming from the steering box. If you feel any roughness in the steering, get it checked out.
I changed my transmission fluid in my 4 speed to 80w140 and I found the synchros worked a little faster. | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Thanks 3B, any idea's as to how much oil i should get? also, i know draining the transmission is a no brainer before adding new oil, but what about the diff and steering box?
Truckernix, i thought the same but my shop teacher said it could just be that any left over grease/oil has hardened/dried and that is what is causing the ticking... i currently have the truck up on stands and the steering wheel turns real smooth, and easy | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, the factory fluid measurements are in pints, you may never have heard of that measurement. There are roughly two imperial pints to a litre. Four speed transmission capacity is 5 1/2 pints, rear axle capacity 6 pints, steering box is probably less than a pint, hope that helps. | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | | | |
