4 members (Nick in Manitou, baldeagle, Lightholder's Dad, Hotrod Lincoln), 50 guests, and 2 robots.
Topics128,014
Posts1,055,333
Members48,419
#77331 05/09/2007 2:37 AM
I've read about the 1000 hour maintenance of the distributor, just hadn't gotten to that on my list o' stuff to do until today. I'm replacing the distributor with a rebuilt, and in the process of moving things from the core to the new unit, ran into this: the way I see it the grease cup (item #2) drives grease to the distributor shaft by rotating it. Whats confusing to me is item #4, the fiber plug. It is flat on one side , concave on the other, obviously from riding on the shaft. It seems to be quite hard, more than I expected. Should I replace it? If so, any idea where to get one? Sorry this was so long. Ed
There was no response to above :rolleyes: , so I just put the old fiber plug in where I thought would be right. The grease cup almost did this distributor in, plenty of grease in there! Put some more pics on the page on how it looks now.
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
#77332 05/12/2007 2:50 AM
Bump, added some more pics.
#77333 05/12/2007 5:16 AM
This setup is designed to take any play out of the shaft. If the round disc is not worn to thin than reuse is fine.
My Blog
#77334 05/12/2007 5:30 PM
Thanks pre68dave, I was sure the spring was for more than just holding in the fiber plug, it's kinda hefty! Ed
#77335 05/17/2007 3:24 PM
should the Grease cup should be tight to the Distibutor???? M/G
HURRY UP AND WAIT 55 235 3/4
#77336 05/17/2007 5:06 PM
The grease cup should not be tight to the distributor. It is a metering device meant to be turned 1 turn for each 1000 miles driven and refilled when it begins to tighten.
My reference is the 1000 hour maintenance hyperlink in fredoly's first post above.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#77337 05/17/2007 10:01 PM
Wow...I did not know that...Mine is tight,What type of grease...(oil) goes in the grease cup??Sorry...I am learning as I go..I have done a lot of reading out of my Shop Manual..ect...But I just cant take everything in, Its overwellming at times. M/G
#77338 05/17/2007 11:56 PM
There's probably some recommendation in the manuals, but, when you think about what its doing, I think you can get by with any good grease that resists water.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
#77339 05/18/2007 3:45 PM
Mike, the cup body is a 1/8"npt it should be tight in the distributor housing, the cup itself should be filled with chassis grease as per the spec in the manual.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
