2 members (PAUL Berardi, 78buckshot), 175 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#773175 08/20/2011 12:19 AM
I just picked up a Dana 45 rear end with 307 gears. I'm told it came out of a 58. The gear set says 11/57 43/14. I'm assuming the 11/57 was date of manufacture. The backing plate and brake drum has about a 1/2 inch offset inboard. The 57's are flat.
My question, will my backing plates from my 57 bolt on? That way I can use all my new 57 brakes and cables.
Ralf #773237 08/20/2011 4:08 AM
I installed one from a '59 GMC in my '56 Chevy. I used the GMC (Dana) drums with my Chevy shoes and innards. I have had no problems.
I have no idea if you can change backing plates and use Chevy drums.
Cletis #773286 08/20/2011 9:52 AM
I'll pull both apart and see. If it doesn't work, I'll get the 58 drums turned or replaced and get new e brake cables.
Ralf #773584 08/21/2011 2:22 PM
The rear end is in, and I used the backing plate that came with it. Needed to use the 58 parking brake shaft because of the offset. Luckily the rear end still had the brakes attached so sourcing the part wasn't a problem. The brake drums are shot, so need to source a pair.
