| | | Forums66 Topics128,281 Posts1,058,479 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | so i got this thing completely detached and couldn't lift it out as it was hitting the two braces attached to the inner fenders. is there a way to get this thing out without removing either the inner fenders or the front sheet metal? thanks ya'll
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The radiator support is attached to the inner fenders, outer front fenders and the grille support, so make sure all of the bolts are removed, in order to remove without complete disassembly of the entire front clip.
| | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | thanks, i got all the bolts out and it is free, it'll come up about an inch and a half before it hits the braces that extend from the inner fender forwards toward the grill. the braces seem to we welded to the inner fenders (just opposite the engine on both sides) and the core support was bolted to them... just hoping theres a trick to sliding this thing out that i'm missing. thanks for the help also it's a 62, don't know if that makes a difference in core support...
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The grille support needs to be removed, as I recall, in order to remove the radiator support. | | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | | | |
