Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (55shaker, 3B, 1 invisible), 144 guests, and 3 robots.
Topics128,281
Posts1,058,472
Members48,490
1 Offline
so i got this thing completely detached and couldn't lift it out as it was hitting the two braces attached to the inner fenders. is there a way to get this thing out without removing either the inner fenders or the front sheet metal? thanks ya'll
The radiator support is attached to the inner fenders, outer front fenders and the grille support, so make sure all of the bolts are removed, in order to remove without complete disassembly of the entire front clip.
1 Offline
thanks,
i got all the bolts out and it is free, it'll come up about an inch and a half before it hits the braces that extend from the inner fender forwards toward the grill. the braces seem to we welded to the inner fenders (just opposite the engine on both sides) and the core support was bolted to them...
just hoping theres a trick to sliding this thing out that i'm missing. thanks for the help
also it's a 62, don't know if that makes a difference in core support...
The grille support needs to be removed, as I recall, in order to remove the radiator support.
1 Offline
awesome. thanks again.
