7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | Finally started to drive my 54 chevy truck and found oil spots On the tail gate and on the front of my buddy's 47. Who was following me to a show. Any suggestions on what would cause oil from the exhaust pipe. Unburned! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd look underneath the truck for signs of oil. When driving oil leaking can end up on the rear of a vehicle and for sure end up on a vehicle following. You might look at the rear main area, oil line connections, valve cover gasket and side cover gasket. It might help to take the truck for a good ride and get things warmed up good. Then park and start looking for oil leaks. | | | | | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | I do have some slight oil leaks but the oil is inside the pipe so I'm thinking some thing internal. Not sure where to start looking. Valves, head gasket, oil pump pressure? | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | How many miles do you have on the engine since it was built? It's not uncommon to have some oil consumption during break-in, but yours sounds like it's a little excessive. Bad exhaust valve guides and/or valve stem seals will allow oil to get into the exhaust without being burned in the combustion chamber, also. Jerry
| | | | | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | I think I am also tending to believe it is an exhaust valve issue. but time will tell. Next opportunity I have, I will check spark plugs to see if they are fouled then pull the cover and check the seals with compressed air. Just having too much fun driving it right now. | | |
