| | | Forums66 Topics128,042 Posts1,055,601 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thank you very much for taking the time to do this. I'm rewiring the amp gauge in my 1949 now and I can hardly read the diagrams. With the color added it really helps. Thank you again. Steven | | | | | Joined: Aug 2011 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 30 | Thanks, I saved the PDF format and now I can load it on my IPad and have a nice diagram that I can zoom in on right in the truck with me.
------------------------- 1950 Chevrolet 3100 5 window Original 216ci and SM420 4-speed
| | | | | Joined: Oct 2010 Posts: 6 New Guy | | New Guy Joined: Oct 2010 Posts: 6 | This is my first posting. I'm new to the forum usage. I am also electrically challenged. I have a stock 52 chevy, 12 volt. Put in new gas gauge. Wire from sending unit goes to which post on gauge, one nearest to E or F on the face? Other wire to ignition, correct?
Mike in Sycamore, IL | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | look at your wiring diagram - see where there is a line labeled "dash panel" - the front and back of the truck [headlights/tail light] relate to the dash line, the wires go exactly as shown, left and right also, if you don't have a manual, find it here, also separate wiring diagrams there Bill
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Mike -
I installed a new 12v gas gauge from The Truck Shop in my '54 this week. The gauge should be marked with a "+" for the lead to the ign sw and with an "S" for the lead to the sender. The "+" on my gauge is behind EMPTY and the "S" is behind FULL.
Sand the cluster housing behind the gas gauge to clean metal. The back of the gauge needs to ground to the housing.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 6 New Guy | | New Guy Joined: Oct 2010 Posts: 6 | Thank You guys for the fast and concise answers. Will be great to have a gauge that does something!! | | |
