2 members (baldeagle, MickeyP), 101 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#7716 08/13/2002 1:41 PM
Hello fellow truck nuts...
Well the wife made it home with the new 54 3600 last weekend, 16" Radials on the back, and 15" biased-2 piece rims on the front...but now I have a tire/rim question. The 16" rims that came "with" the truck interfere with the tie rod ends...I went to my trusty hardware store and got some 1/8" thick washers to offset, but now I have two washers, and I am getting to the end of my studs.
I was thinking of pulling the drums and having longer studs to put in, then using a spacer...maybe 1/2" or so...
Comments...
Jim
#7717 08/14/2002 7:13 AM
I reccomend NOT using spacers on the front.
I suggest finding wheels that have the correct off-set cool
#7718 08/14/2002 7:58 PM
Someone here had found some 16" Dodge rims that worked.
Fred
52 3600
69 C-10
#7719 08/14/2002 11:10 PM
I have used 1/4" spacers and longer bolts on my daily driver since '95.
Not the slightest problem since about 80K in the city, on mountain roads and freeways, nn TX and CA.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#7720 08/14/2002 11:23 PM
Try out a 16 inch wheel from an 80's F truck. They have less backspace and no one will ever know.
Porky Pig is just a ham.
#7721 08/14/2002 11:27 PM
Are you looking for stock appearing wheels?
#7722 08/15/2002 3:52 AM
Add my name to the list of those that recommend that you DO NOT use any spacers. You change the dynamics of the wheel forces and it's one of those things that may hold for years and may snap all the studs at one time...no way of knowing until it happens.
Those rims want to be butt up against the drums to be properly mounted.
Tie rod rubbing is common in the incorrect rims.
Try calling Wheel Vintiques as they have dealt with a lot of this and may have a solution.
I run the stock 15" 8 LUG splits on my 3/4 ton.
#7723 08/15/2002 1:57 PM
So why are you discussing that today and not last week???? wink
I just went through this problem yesterday.
1ton 1953 truck with 17' split rims and tires the same age.
I found 4 used 16" rims the 2 rear wheels where ok
to be fitted. One front one was no problem and the last one jammed on the tie rod end.
I was sligtly p......
Started comparing the rims and found that the offset was different. I laid across the inner side
of the rim a ruler and meassured down to the mounting hole, Yes there is a 3/4" difference.
So back to the scrap yard to exchange one rim
came back to the tire dealer and still was the wrong rim. correct offset but different width at the safety beat.Back to the scrap yard. found another rim different looks and different width.
I found so far 4 different 16" rims
the width by the safty bead is as following
6"-6.5"-7"-7.5"
So if you get a 16" tire with the width of 6" and the offset should be 4" from the lower step on the safety bead you should be beable to mount them on the front.
My tire dealer told me I could use a Dodge space.
The have to put them on the 2000 model right front tire only, as the disc brakes will touch the rime after they wear down.
I was thinking to put spacers between the axlehousing and the steering arm which attaches to it and connect to the tie rod.
Any comment on that thought?
Also how much space should be between the rim and the tierod end???
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#7724 08/19/2002 4:18 PM
Jim, This is what I wrote to Fred T a little while ago.
Fred T and others,
I finally took a front wheel off my 3/4T and did some measurements with flat boards spanning the 16 in. one-piece rim. I come up with an inside bead width of 6 in. (not 6.5 like I thought). The inside mounting surface is setback 3 3/4 in. from the outside of the bead. These rims work with 235-85R16 tires (Michelin highway treads) which came off my '90 D**** 3/4T. One of the tire shops in town said they could order them so they should be available everywhere.
#7725 08/20/2002 3:46 AM
Wally, did the rims come off the 90 D**** or the tires. I'm more interested in what year and make truck the rims came from. I'm wanting to go to one piece rims also. Thanks, Ken.
Drive it, or sell it to someone who will!!
#7726 08/20/2002 6:28 PM
I think I once said that the rims came off a D**ge but THEY DID NOT. Only the tires. (Feeble brain, sorry.) I got the standard gray rims at a tire shop. One shop in town (Les Schwab) had rims that were too wide but were cheaper. I put two of those on the back. Another shop (our Tirerama) had the right ones in stock so I put those on the front. Of course, now I can't rotate my tires (again, feeble). I use an old split rim which fits the front for a spare.
I'm ready to rotate better tires from the D**ge to the '48 again and I'm hoping they work also.
