5 members (JW51, C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 111 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
#766026 07/27/2011 3:01 PM
Does anyone know of a kit to convert from lever shock to coil shocks, that just consists of the mounting brackets? I found this one, http://secure.oldchevytrucks.com/SHOCK-ABSORBER-CONVERSION-KIT-1936-1949-1_2TON/productinfo/HP590/ but I figure I could probably save some money by buying the shocks separately from somewhere else. Also I only need the fronts, I already have tube shocks for the rear.
1940 Chevy 1/2 ton, 12 volt, 350/350th
That same vendor sells brackets separately....See here:
http://secure.oldchevytrucks.com/Shock-Mounts/products/575/
You Tube
Thanks, but I have a 1940. I don't think those will work.
I would like to convert to tube shocks also, those single action lever jobs don't cut it! But, everything I have seen is a do-it-yourself fabrication. May have to go that way, but hope some more folks will respond with how they have done it............?
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
I made my own brackets for the frame and reversed the axle mounts right to left on my 4t6. I don't how well it will work as it's still taking up residence in the garage. Some pics start here. May give you some ideas. Have fun and good luck
Dan
Dan
Let me know how they work out for you, thanks!
