1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77196 05/07/2007 4:34 AM | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | Looking for an intake manifold for my 1991 350 motor. The Edelbrock site lists this:
"Performer - For 1987-95 Cast Iron Cylinder Heads: Designed for street 262-400 c.i.d. Chevy V8s equipped with factory cast iron heads with canted center bolt holes. Will not fit 1987-95 factory aluminum cylinder heads. Will not fit Chevy Bowtie or LT1 heads."
Does this mean that if I went with a stock manifold I would have to get one from those years due to the "canted center bolts" on the cast iron heads?
So nothing pre- 87 would work?
Thanks for the input.
Carl
CCB
#77197 05/07/2007 6:32 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy cbrackle, I think any manifold for any 350 back to 68 would fit the application you describe, But I'm no expert on this new fangled stuff, hope that helps. | | |
#77198 05/07/2007 3:29 PM | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Carl, The stock manifold uses a throttle body, so that's probably not what you are looking for. I understand that you could make the earlier manifolds work by modifying the center bolt holes. I have not done it but it seems feasable. Fred
#77199 05/07/2007 6:42 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I've seen earlier intakes fitted to 87-up engines by elongating the center bolt holes,if you don't have the coin for the Edlebrock. | | |
#77200 05/07/2007 6:57 PM | Joined: Mar 2007 Posts: 3,396 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,396 | I've modified older factory and aftermarket manifolds (pre 87) to work with these heads without any problems. To use an older intake you need only change the angle of the two center holes on either side. You can do this by using a 7/16" drill bit to and enlongate the holes. I would add a washer under the bolt here to help pull the intake down evenly. If your going to buy an aftermarket manifold then the Edelbrock is the way to go. Good luck.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
