0 members (),
51
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've been seeing braided battery ground cable for sale at swap meets. I ask what gauge they are and get blank stares. How can one determine the gauge by looking at them? measurement? Thanks Don | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | They are so thick and have so much metal it would seems they wouldn't even have a gauge rating... I use them for grounding battery to firewall, engine to firewall, and engine to frame. I've heard of people grounding the bed to the frame as well. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a discussion about grounding locations that was posted yesterday. Yes, there are different gauges of ground cables. I would not buy one at a swap meet unless the gauge was listed on a packaging label. Most of them would most likely be 6 gauge (or 4 gauge at best). You can get braided ground cables down to 2/0 (00) gauge. Tractor Supply Corp. has 2 gauge and 4 gauge braided ground cables (battery to frame), but they are not very long. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Grounds are like money, you never have enough.
~Jim
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Grounds are like money, you never have enough. . . . and, the bigger the "denomination" (the "gauge"), the better. | | |
