1 members (baldeagle), 50 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#77171 05/06/2007 11:59 PM
Hey Guys,
Thanks for your help figuring out stuff on my 235.
This is a photo of the drivers side of the engine.
See those two holes underneath the oil pressure sensor?
Does an oil filter get plumbed into them?
#77172 05/07/2007 12:11 AM
I have no clue what it is, but I can tell you it isn't for a filter. The filter would get its supply from a T fitting from the oil pressure port, and return in a hole further up on the block.
Bill Burmeister
#77173 05/07/2007 1:19 AM
Those are just threaded holes to mount a bracket for clutch linkage on some models. If you clean them out, there will be threads in a blind-bottomed hole, no connection to any oil passages.
#77174 05/07/2007 1:34 AM
Cool!
I feared that I was going to pump all the oil out of the engine.
It's strange that the 235 doesn't have an oil filter as standard equipment though. ohwell
#77175 05/07/2007 3:53 AM
I'll just bet if you push a putty knife around through all that accumulation of road gunk you'll discover a 1/8npt plug that have been used to eliminate pressure side of the bypass filter.
Just above the bottom lip of the engine is an oil gallery that runs from front to back. This is the pressure side. A couple inches above it is the return gallery...same front to back. That's where your sensor is located.
Above the return gallery, towards the back of the engine is the threaded throttle bell-crank mount where your gas pedal forward motion is changed to up and down motion to work your carb linkage.
Eliminating the bypass filter will pick up 5-7 more pounds of oil pressure. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
