0 members (), 119 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
Hi Guys
I'm having trouble ordering hubcaps for my 58' Chevy with 8lug differentials,
Can anyone direct me to a site where you can order these, the LMC site is not that clear for what truck the caps are for.
I live in Namibia and returning parts can be problematic.
I have a 58chevy pickup step side longed. With 8lug rims or floating differentials at the back
Christo
C Loubser
43 Ford CMP 4x4
48 Ford F1
41 CCKW 2 1/2 ton GMC 6x6
57 Land Rover series 1
59 Mercedes 220s
They are not being reproduced to my knowledge. I looked for them for my '59 3/4 ton (8 lugs)and I could only find a few beat up and rusty originals. I went with new aluminum wheels. I've seen a few on Ebay from time to time but none in good shape. All I can say is GOOD LUCK!
What's the issue? The hub sticks out too far or the diameter of the clips? If it is the hub, then just have a machine shop cut a hole in reproduction caps. If it is the diameter of the clips, then I don't have an answer.
I bet your truck gets a lot of attention in Namibia!
Well at the moment both is standing, restoring one converting the other.
How would you go about machining those hubcaps.
C Loubser
43 Ford CMP 4x4
48 Ford F1
59 Mercedes 220s
My take is jomichael is talking about cutting a hole in the center of the hub cap so the hub can poke thru it Christo. That would work to cover up the nuts but not the best answer if restoration is your goal.
The Filling Station lists 1957-60 3/4 & 1 ton truck part number L-315. Take a breath now, $70 each/$240 set of 4.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ouch on price! That hole is looking pretty nice, huh? That's what the factory did with the front hub caps on NAPCO 4x4's.
