1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | Hi all I need some help. I have a 153 tooth flexplate with a 101/2 converter bolt pattern. I am using a th400 trans which lists a 11 1/2 bolt pattern converter. I have read that a th350 converter will interchange it this true. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Yes, the converters will interchange, but the stall speed will be different on the 350 converter. Unless the 350 converter is the same diameter as the 400, the stall speed where the engine RPM stops increasing with the throttle floored and the brakes locked will be higher using the 350 converter. The smaller ther converter diameter, the higher the stall speed will be. There are some flex plates that have a dual bolt pattern so either 350 or 400 converters will bolt up. Jerry
