2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#771661 08/15/2011 3:16 AM
Hi all I need some help. I have a 153 tooth flexplate with a 101/2 converter bolt pattern. I am using a th400 trans which lists a 11 1/2 bolt pattern converter. I have read that a th350 converter will interchange it this true.
Yes, the converters will interchange, but the stall speed will be different on the 350 converter. Unless the 350 converter is the same diameter as the 400, the stall speed where the engine RPM stops increasing with the throttle floored and the brakes locked will be higher using the 350 converter. The smaller ther converter diameter, the higher the stall speed will be. There are some flex plates that have a dual bolt pattern so either 350 or 400 converters will bolt up.
