| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | I removed my fuel pump on my 46 Chevy and after some cleaning and trying to get that one last spot I kept disassembling and realized I need new gaskets. Does anyone know where to get a gasket kit for a fuel pump on a 216? Or preferably the NAPA part number for the gaskets, or will I have to just buy another pump. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It shouldn't be difficult to make if you are stuck. Sorry, I thought I read gasket as in pump to block gasket.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | egge, kanter, jim carter, chevs of the 40's are a couple of places to start. It is getting to the point where you are kind of hard pressed to just go to a store and get parts for these trucks, you usually have to wait a bit. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you go to Napa you can probably buy a replacement fuel pump for less money that a rebuild kit will cost. If you are opening the pump to clean stuff out you should remove the check valves inside. You should also think about looking inside your fuel tank if you have lots of stuff in the fuel pump. Don | | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | Does anyone have the Napa part number, the guys up here can't find the part in there computers. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | If no one responds you could try Napa online web site and ask them. I believe they have a "contact" feature. Then get your local guy to order it out.
Ed
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | They are a stock item at Patrick's, Bowtiebits and Chevysoftheforties if you can't get any help locally. There are single and two stage vacuum pumps. Normbc9 | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Wow, I wish I stocked up on glass fuel pumps 3 years ago! I bought mine at O'reilly for $25 then. Now you can't touch a kit for $40! The cheapest replacement I can find now is at RockAuto for $32. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | it doesn't cost any more, the money just isn't worth anything any more | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ^ x2
Between Autozone and NAPA I haven't had any trouble finding gaskets for the 216 or any of its parts. The manager at NAPA even put in a good bit of time helping me find a suitable replacement gasket for my Innerline oil filter. | | |
