0 members (),
170
7
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77140 05/05/2007 3:13 PM | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Ok, I think I am set on converting my 57 3100 to power assisted disc with under frame booster and keeping the 6 bolt setup.
Now I need some advice on power steering. I want to keep the stock column, unless someone can tell me of a way to put a modern column without it looking like a coble job. I have read about using late model Saginaw pump, anyone have experience with this? Thnaks! | | |
#77141 05/05/2007 4:10 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There is also lots of information posted on this subject, numerous opinions, and lots of suppliers. It's a good idea to replace the ball stud tie rod ends with the newer type on any power steering conversion. I used a Toyota conversion with a conventional GM pump. I also retained the stock column with the original column shifter. You can get the kits from various suppliers. I prefer these guys. abspowerbrake.com Fred
