| | | Forums66 Topics128,188 Posts1,057,331 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77131 05/05/2007 12:09 AM | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | I have a ’51 Chev ½ ton, ’58 235 w/848 head, solid lifters, Fenton headers, and Offy intake manifold w/two Carter/Webers and 3.55 gears.
I pull a 1940 Teardrop Camp Trailer. TD and all camping stuff is less than 1000 lbs.
I cruise at 60 mph and the engine is running at 2550 rpm.
Yesterday I left Kennewick, WA and drove 150 miles.
OK…Here’s what happened then. I felt the engine “drop a cylinder” and it sounded like it was pinging off and on. I immediately turned around and headed back to a small little town with a dumpy gas station with a lot of OLD cars and trucks.
I pulled the valve cover in his parking lot and found the #6 exhaust valve spring keeper had broken and the valve was about 1 ½” down into the head.
Friends came the 150 miles with two rigs. One to tow the ’51 and one to tow the TD home. When I pulled the head off today, I found that the valve stem seal was what saved a major catastrophe. The valve is good (never touched the piston) and the pushrod is straight.
I should get the head back on Monday afternoon.
WHEEEEW!!!
Thruwurkin
Half Ton Will Travel God bless America...One nation under God
#77132 05/05/2007 1:01 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well, even though you had to scratch your trip, at least it's not as bad as it could've been. Seems odd a keeper would break, I don't think I've ever heard of that happening but obviously it does. | | |
#77133 05/05/2007 4:57 AM | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I know of three guys that have had keepers fail, all dropped the valve and holed a piston. You were lucky, most of my experience is with motorcycles, but again I would say you were lucky. Little luck never hurt nothing - I will take all I can get. | | |
#77134 05/05/2007 5:19 AM | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | Youre one LUCKY bolter!!! Im sure you know how bad that could have been. Even though you had to cancel your trip,,thats a small price to pay for what could have been a major BUMMER. Marty | | |
#77135 05/05/2007 1:35 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I lost a valve keeper once and dropped the intake valve on #3 cylinder in a 216, lucky to be intake valve, it never dropped down far enough to do damage, only bounced off the piston and made a little noise. I put new keepers on it and continued to drive. | | |
#77136 05/05/2007 2:13 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have always wondered how these tiny litttle keepers manage to do perform such an important role without failing. It is truly amazing to me. | | |
#77137 05/05/2007 2:49 PM | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | I was looking in my repair manual and it appears that I posted that the wrong part broke. It was the valve spring CAP that gave up, not the keepers. I retrieved the two small keepers and the cap pieces from the rocker arm area. It seems that nothing went any lower than that.
When I was along side the road, I didn't think I broke a piston because there was no blowby from the crankcase vent.
Sorry for the confusion.
Thruwurkin
#77138 05/07/2007 10:15 PM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Either way, Thruwurkin, the Man Upstairs was looking out for you. Glad it's turning out well for you.
Neil 1940 GMC 1/2 Ton
#77139 05/08/2007 2:59 PM | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | The man upstairs was definitly looking out for me.
I never heard of a something like this happening and not trashing at least a piston.
I should get the head back from the machinist today and will start reassembly late this afternoon. He is cleaning up the seat and checking the rest of the head.
Thanks all for your posts. It is a big help to hear from others.
Thruwurkin
