| | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 6 New Guy | | New Guy Joined: Jul 2009 Posts: 6 | Okay I am putting truck back together doors are on but not lining up correctly, but are close with the body lines. My problem is where the striker is to catch the striker plate I have almost a half inch of door sticking out as it is like it is not catching properly. Any suggestions? | | | | | Joined: Aug 2010 Posts: 24 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 24 | How worn is your striker plate? If well worn you could try putting a spacer (try a couple washers) between the striker plate and the cab to push the striker plate out a little bit more for the door to catch on a little less worn area. | | |
