| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I've got a 41 the horn was working just fine until the other day, I took it out of the truck opened it up and found that the 2 leads soldered on to what I think is a capacitor had broken off. http://s1112.photobucket.com/albums/k483/Hotrod_A/?action=view¤t=IMG_0129.jpgDoes anyone know the specs of this part so that I can replace it? Thanks, Rob | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I see you multi posted your question. That is frowned on. Cletis will delete your post in GTT or you can do it yourself. Go to your post and click edit then select delete if you want to do it yourself.
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Thanks, I figured why not double my chances of getting an answer. | | |
