2 members (Biermann, papas52), 154 guests, and 2 robots.
Topics128,164
Posts1,056,975
Members48,458
#771137 08/13/2011 4:04 AM
I am trying to put a 700r4 tranny to a 250=230 chevy 6. What size of flywheel do you use? I have a flywheel from a 350 but it don't work.
There are 2 flexplates that will work on both 350 (and all pre 86 V-8's) and the 230/250 6 cylinder engines. One is a 168 tooth and the other is a 153 tooth which is smaller. You may have gotten one from a later 350 (86 up) which will not work as it has a different bolt pattern.
Fred
I must have a 168 tooth on it now. It bolts up to the 230 but it's to big for the starter to bolt up. i will find a 153 tooth and see what will happen. thanks
