6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 49 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#770766 08/12/2011 1:29 AM
i have a 49 chev with a 350/350 combo....battery is in the stk location,on the frame under the floor...when grounding the battery to the engine is it acceptable to use one of the starter mounting bolts to attach the cable to.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
not only acceptable, but preferable, puts the ground right where the biggest load is
3B Offline
Hy david dyehouse, if you could use a transmission to engine bolt it might be better, the vertical starter bolts are length sensitive and their torque might not hold while retaining the cable.
You can't over ground your Bolt, here there and everywhere.
~Jim
I ran mine from the battery to the starter bellhousing bolt. Works perfectly and I believe it is where the factory ran it.
The factory didn't install 350s in AD trucks. A strap on an AD six starter is fine. But as Bobb pointed out, it is not fine on a 350 starter.
Busted on that one. But the fact is, I grounded my 55.2 350 at the starter bolt, the firewall, and frame and all is fine.
