| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i have a 49 chev with a 350/350 combo....battery is in the stk location,on the frame under the floor...when grounding the battery to the engine is it acceptable to use one of the starter mounting bolts to attach the cable to.......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not only acceptable, but preferable, puts the ground right where the biggest load is
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy david dyehouse, if you could use a transmission to engine bolt it might be better, the vertical starter bolts are length sensitive and their torque might not hold while retaining the cable. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You can't over ground your Bolt, here there and everywhere.
~Jim
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I ran mine from the battery to the starter bellhousing bolt. Works perfectly and I believe it is where the factory ran it. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I ran mine from the battery to the starter bellhousing bolt. Works perfectly and I believe it is where the factory ran it. The factory didn't install 350s in AD trucks. A strap on an AD six starter is fine. But as Bobb pointed out, it is not fine on a 350 starter. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Busted on that one. But the fact is, I grounded my 55.2 350 at the starter bolt, the firewall, and frame and all is fine.
