0 members (),
84
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | Hi Guys I just installed a high torque 3hp starter on my 350 which lives in my 1950 1/2 ton. What a difference! Instead of grunting when trying to start a hot engine it now sounds like I'm cranking up a jet engine. Best $75 I've spent in a long time. http://s845.photobucket.com/albums/ab15/joetravjr/ | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Hello, did you have to shim the new starter? If so, was it difficult?
| | | | | Joined: Feb 2009 Posts: 12 New Guy | | New Guy Joined: Feb 2009 Posts: 12 | Hi APV60, It was a simple bolt in, no shims needed. The starter comes with (2) shims if needed. Before the new starter it would give me a hard time when it was hot. Now it spins really quick. A rebuilt starter from NAPA cost the same, but what a difference. | | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | Did you check the tooth engagement on the starter gear, or just assume that it was right? I like to spray-paint a few teeth on the flywheel, then run the starter and see how much of the paint gets rubbed off. If the starter gear teeth are bottoming out in the flywheel ring gear, install shims until there's a small area of paint left at the bottom of the tooth contact area. Jerry
| | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | | | |
