3 members (Woodcmiami, Cosmo, 1 invisible), 75 guests, and 2 robots.
Topics128,150
Posts1,056,991
Members48,460
Recently I performed an engine flush on my 216CI 6 installed in my 51 Chevy 3100. Now I have noticed after running the engine up to temp I get a small ammount of water slinging off of the spinning clutch/flywheel assembly and exiting out of the timing pointer hole in the bell housing. I suspect expansion (freeze) plug failure (yikes). Can anyone tell me how many are on the back of the block? Sizes? and a jobber that stocks them?
Thanks in advance
Best Regards
Will
If it is like the 216, it will be a 2" convex disc. It will probably be the same as the one in the front of the block. Here is what mine looked like:
http://rides.webshots.com/photo/1316417356041873203xTDshC
1951 1 Ton Completed
truckernix,
What a excellent picture. These 'in progress' pix are worth more than a thousand words...yours even has leaking anti-freeze added for effect! smile
Stuart
Yup, you will have to pull the bellhousing to get at that plug. A pain in the neck.
Paint & Body Shop moderator
atomarc,
actually when the plug came out, there was a wall of rust/mud in there. After I gouged it out, the antifreeze appeared!
