| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77045 05/02/2007 6:08 PM | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Recently I performed an engine flush on my 216CI 6 installed in my 51 Chevy 3100. Now I have noticed after running the engine up to temp I get a small ammount of water slinging off of the spinning clutch/flywheel assembly and exiting out of the timing pointer hole in the bell housing. I suspect expansion (freeze) plug failure (yikes). Can anyone tell me how many are on the back of the block? Sizes? and a jobber that stocks them? Thanks in advance
Best Regards Will
#77047 05/02/2007 7:39 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | truckernix, What a excellent picture. These 'in progress' pix are worth more than a thousand words...yours even has leaking anti-freeze added for effect! Stuart | | |
#77048 05/02/2007 9:57 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yup, you will have to pull the bellhousing to get at that plug. A pain in the neck.
#77049 05/04/2007 12:49 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | atomarc, actually when the plug came out, there was a wall of rust/mud in there. After I gouged it out, the antifreeze appeared! | | |
