| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 13 New Guy | | New Guy Joined: Mar 2005 Posts: 13 | 10 years ago when I repowered my 50 1 ton chevy with a V8 auto, I used a air cond condenser for a trans cooler, although I did"nt know how hot the trans fluid got I did drive it cross country with a full load and used it as a daily driver for 3 years with no trans problems while using the stock radiator the whole time. I"v searched the net and have"nt heard of anyone who"s cooled a trans with a ac condenser.... mabey there"s a good reason or mabey I"m just a cheap but crafty old sob! any thoughts? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If you are looking for confirmation of you being cheap you probably need to ask your wife or kids. Sounds like a safe bet though. As for the trans cooler it sounds like a functional solution. | | |
#7703 03/11/2005 11:39 PM | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I have been using a power steering cooler from 1978 f#&d f-150 for about 7 years now. I don't haul many loads but havent had any problems. O, yeah, it was a freebie and i used the clamps that came on it. Bought about 2 foot of fuel line though. | | |
#7704 03/12/2005 12:54 AM | Joined: Mar 2005 Posts: 13 New Guy | | New Guy Joined: Mar 2005 Posts: 13 | | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | i got a hot rod truck thats not together yet but it has a very small chrome tranny cooler its like 4 by 6 by 9 will this be good it sure dosnt seem like its big inuff to do the job | | | | | Joined: Mar 2005 Posts: 13 New Guy | | New Guy Joined: Mar 2005 Posts: 13 | If I were you I"d install a temp sending unit and of coarse a gauge on the line before the oil cooler to monitor the trans fluid temp, then you"ll know if your about to have a tranny roast. Thats what I"m going to do cause I"m not to keen on dropin $475 for a radiator with trans cooling ability when the stock rad will work just fine. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The only problem I see with using an AC condenser is that the coils may be too small and restrict the oil flow from the transmission, causing too much pressure drop. Check the oil pressure at the transmission to make sure the cooler isn't restricting it. Too little pressure might make it slip or cause funky shifting problems.
A good cheap cooler would be to find an oil cooler off a motorcycle, junkyard Porsche, SAAB, or BMW. All '88-92 BMW 325i's have a nice rectangular oil cooler mounted right below the radiator that hooks up to the engine oil and flows pretty well. They are easy to get out if you can find one at a U-pull-it, and they rarely go bad.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 13 New Guy | | New Guy Joined: Mar 2005 Posts: 13 | that coyote is just a stubborn sob ( I can relate to that) and he wanted THAT bird! Or maybe its just about the chase. | | |
