4 members (78buckshot, Roy Rodgers, Gray_Ghost, 2-Ton), 100 guests, and 0 robots.
Topics128,113
Posts1,056,279
Members48,439
#770264 08/10/2011 3:05 PM
Need help with my huck brakes. Attached are pictures. Looking at the pic in the manual, there appears to be a center set of braces that I don't have. Also, for the park brake, I got the arms and spreaders from bendix brakes but they don't seem to fit the hucks. Do I need huck e-brake arms and spreaders? The brakes work but am I missing some center pieces as well?
http://i1108.photobucket.com/albums/h416/ssgummersall07/IMG_20110810_070124.jpg
http://i1108.photobucket.com/albums/h416/ssgummersall07/IMG_20110810_070143.jpg
Yes, you need the spreader bar and associated compression spring and the pivot arm with a washer and cotter pin for the ebrake.
Drew
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Thanks for the advice and the pics. Looks like the huck spreader is a rod rather than the flat bar used to spread the bendix brake system...I am on the search for two spreaders with springs for 1950 half ton huck brakes!
