10 members (Lightholder's Dad, gswbbc, FAST55, 48jim1ton, frogfarmer, Gdads51, tclederman, Ponchogl, 68ironhead, 1 invisible),
135
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | Iam going to rebuild the master cylinder and then bleed the brakes. My truck is original, so the bleeder valve is not a nipple. It has a screw to remove before bleeding. How does a person attach a bleeder tube to the original valve? The manual refers to a tool that screws into the bleeder valve--where do you find one of those? I appreciate any input.
Lee Beckman | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | from Wrenchbender Ret. :
The old style bleeder hose came with a screw that goes in the hole after you take the plug out. I dont know if you can still buy one like that. I just let the fluid run down the backing plate but Im kinda a slob. I will look tomorrow & see if I have one of those.
-W | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | All i ever did with my 55-2 was take the cap off the master cy an ease the the petal down and the air would bubble up ..job done . | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I dont have it any more. You could put some later model bleeders in till you get them bled & Then put the original back in to keep it original. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | Thanks for the input--I appreciate it
Lee | | |
