4 members (KEVINSKI, Guitplayer, Samantha, lumbersawyer), 109 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
I want Bendex brakes. I have a 41 1/2 ton. I just got done removing the rivets that hold on the backing plates to the rear end. I got me a '55 1/2 ton rear end that I'm gonna put those backing plates onto my '41 so I can have bendex brakes. It's kinda late to ask now, but does any one see a problem with what I'm doing?
Yeah, why didn't you just use the entire 55 rear end? Was it because of lug spacing? headscratch
~Jim
The '55 has a total wheel base that is too wide for me.
Bump. I need an answer, thanks.
You may run into different offsets with drums and backing plates and possibly need to space something out or in to get the new drum to sit even with the axle flange. I am just speculating and don't have direct experience with your application, but those are some issues I've run into with rear brakes on medium duty trucks.
Let us know how you make out.
Steve
'49 3800
'52 3600
'57 3100
I don't know about doing a '41, but I did a '50 without much problem. Did resize some mounting holes to a larger diameter. The main thing is to make sure size will fit the rest of whatever you are planning on using such as drum diameter and width,wheels,spacing.
Drew
Thanks for the heads up. If it don't work out I guess I'll be posting into the "stovebolt blunders" thread.
