5 members (stlcardinalsguy, Leo, mick53, Ponchogl, Mike B), 87 guests, and 3 robots.
Topics128,180
Posts1,057,156
Members48,464
Hi.
Just got a "new" air cleaner home from EBAY.
It had some small holes in it, so OIL BATH is out of the scope.
Now to my problem.... If I am supposed to use a paper replacement filter, how do I do with the hose that comes from the valve cover? It will end up inside of the paper filter, and that oily air will not be filtered as I can see.
Anyone who has a similar oil bath air cleaner and has done a conversion?
http://i185.photobucket.com/albums/x264/uffeg/Viking%20Engine/20110809424_filter.jpg
Rockauto has a version that will probably fit the inside. But I want a filter that is more thick so the connection from valve cover comes down on top, and also will be filtered....
http://www.rockauto.com/catalog/moreinfo.php?pk=55358
Any suggestions ?
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
MAybe you can fit one like these inside :
Not this wide and a bit higher....
http://www.summitracing.com/parts/KNN-66-3040/
Hopefully it can be possible to find something cheaper.
Cheapest is to fix the holes in the original filter of course smile
So I guess that's what I will do in the end....
[email protected]
Also:
