7 members (FAST55, Hanks custodian, mick53, baldeagle, 50Chevy3100, Donf, TUTS 59), 71 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#769398 08/07/2011 7:58 PM
Im getting my drums turned for a '51 1 ton and need to know what specs they should me turned to, does anybody know?
Josh_51GMC #769436 08/07/2011 10:32 PM
1 Offline
I do not believe there are any specs involved. What you want to accomplish is to get all the grooves out and still end up with enough "Drum wall" to dissipate the heat . More brake pureists may chime in and discredit what I believe.
1951Chevy1Ton #769439 08/07/2011 10:37 PM
I think he's right. Just make sure there is enough thickness to the drum. You can adjust the brake shoes to fit a slighter larger diameter, so there is no specification in that respect.
Minimum thickness of the drum is what you'll have to check for. Maybe someone in the know can post it.
Dave Baird
1951 Chevy 3803
Dave51Chev #769449 08/07/2011 11:28 PM
Ok thanks, i do believe somebody posted it being .090"
Josh_51GMC #769476 08/08/2011 2:22 AM
It's actually maximum diameter when dealing with drums, and there is a specification for it. As Josh has mentioned from the other post on this subject, .090 over nominal is the maximum you would want to go and still mainatan a safety margin. Most drums have a machine to spec of .060 over nominal, with the .090 being the discard spec, as you would not want to go any firther than that.
Bill Burmeister
LONGBOX55 #769505 08/08/2011 3:44 AM
ok, so correct me if I'm wrong.
When having the drums turned or machined, that increases the diameter, and you only want to go a maximum of 0.090 over stock. but when having the drums turned you want them turned until all the grooves are out, so if i get my drums turned and they are "smooth" within that 0.090 maximum then my drums are fine to use?
Josh_51GMC #769510 08/08/2011 4:00 AM
Even if there are a few minor grooves left at the .090" oversize point, as long as most of the drum surface is smooth and straight, go ahead and re-use the drums. The major reason to turn a drum is to get a smooth, straight surface, with minimum out-of-round. A few small grooves don't really cause a problem, as the lining will wear in to a perfect contact within a few miles.
The owner of a small trucking company where I managed the shop insisted that a grooved drum added area to the brake, and he wouldn't let me get drums machined. The "golden rule" applies here- - - -the guy with the gold makes the rules! I coudn't convince him he was wrong, so I just did it his way!
Hotrod Lincoln #769565 08/08/2011 11:25 AM
I would say be extremely careful here. Replacement drums for a 51 1 Ton are extremely rare and very hard to find. You don't want to have your drums ruined by too much machining. In the past, I have found two references in the shop manual for the maximum diameter that they can be turned to. For the smaller drums it seems to be .060" and for the 16" and up I believe it was .125".
1951 1 Ton Completed
truckernix #769764 08/08/2011 11:09 PM
Ill take a look in manual once I find it haha, but I do believe I have 15" drums
Josh_51GMC #769859 08/09/2011 2:50 AM
Usually the drums are refered to by the inside diameter which in your case is probably 14".
truckernix #770115 08/10/2011 1:13 AM
alright, well i guess ill just have to giver a shot and hope the drums will still be think enough.....
Anybody know any tricks as to how to get a seized drum off? im taking the fronts off, coated the drums in loctite oil and was able to maybe get it 1/4" off the hub (with a lot of choice language and prying)... and now its stuck
Josh_51GMC #770129 08/10/2011 2:00 AM
1 Offline
I just removed (2) 1 ton drums this week. Back off the adjusters till they dont back any more. Use about 2 or 3 long pry bars/ Screwdrivers. Bang on drum with the biggest BFH you have all around edge. I AM not talking a 16 ounce claw hammer but a BFH. Drive one pry bar between drum and backing plate at the 12 o clock area and force the drum outward. BFH the oposite side of drum. You will see movement. Use the other pry bars at the 8 and 4 o clock positions and force drum out ward. Use BFH again all around the drum. It is moving , isn't it. Dont give up, just keep working the pry bars and the BFH. When the drum falls to the ground, grab a cold bud , then start the other side. The key to it is to get the adjusters backed off and to break the rust around the lug bolts and the drum.
1951Chevy1Ton #770161 08/10/2011 3:31 AM
Are you trying to remove the front drums from the hubs? I think the machining is done with it still on the hub.
truckernix #770162 08/10/2011 3:33 AM
Im trying to just get the drum off so I can get at the wheel cylinder and brake parts
Josh_51GMC #770304 08/10/2011 5:22 PM
and hopefully find out if the small crack on the front drivers drum is gonna cause me trouble or not....
Josh_51GMC #770309 08/10/2011 5:31 PM
Where is the crack located? If it;s just on the outer lip area, it shouldn't be a concern, but if it's in the actual braking surface, you'll need a replacement drum.
Bill Burmeister
LONGBOX55 #770445 08/11/2011 12:36 AM
its ont he top of the outside of the drum... where the grooves are?
Josh_51GMC #770461 08/11/2011 1:27 AM
If it's scored deep enough to cause a crack, then it's not going to be reusable. Is there any way you could post pictures of the crack location, and perhaps the scoring? Might be able to get a better idea of what you have going on if we can see it.
Bill Burmeister
LONGBOX55 #770714 08/11/2011 10:27 PM
Crack top
Crack side
They dont go all the way through so my guess is they should be fine, the insides of the drum are in amazing shape
Josh_51GMC #770755 08/12/2011 12:43 AM
I hate to be the bearer of bad news, but that drum is not going to be usable. That crack is in a vital part of the drum, and would be a safety issue. I wouldn't risk trying to reuse it.
Bill Burmeister
LONGBOX55 #770803 08/12/2011 3:05 AM
Probably a stupid question but would i be able to TIG weld it together. the pics look a lot worse than the crack actually seems
Josh_51GMC #770813 08/12/2011 3:26 AM
I wouldn't advise it.
Bill Burmeister
LONGBOX55 #771636 08/15/2011 1:18 AM
hmm alright well i guess ill just take it to the shop and see, maybe ill be lucky?
1951Chevy1Ton #775379 08/27/2011 2:11 AM
I totally agree with you but out here in Cali..."the land of fruits and nuts" it's illegal for a shop to turn an out of spec drum. So unless you can do it yourself your screwed!!!
RUSHNBOBO #775387 08/27/2011 2:24 AM
Not just California, all 50 states. I suppose that some of the shadier "mechanics" might turn a drum (or rotor for that matter) beyond the specs just to make a buck, but those of us that actually take pride in our work know better.
Bill Burmeister
LONGBOX55 #775424 08/27/2011 3:42 AM
hmmm, hopefully not in Canada?
Josh_51GMC #775653 08/28/2011 12:47 AM
I think that is preyy well the same here in Canada. Although the specs may be hard to find, I think there is mention of .060" over for the lighter duty trucks and I think starting at the 16" drums it is .125". I would have to do some searching to find the references. Back then I would imagine new drums were plentiful and cheap. Of course, that isn't the case for these old trucks now. Half ton owners have it easy in this department because the market demand is large enough to produce new drums.
truckernix #775704 08/28/2011 4:08 AM
In the manual i have, it has a bunch of "sepcidications" but i have no idea what they mean. if anybody would like i can post them?
Moderated by  Dusty53
