1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#769180 08/07/2011 12:48 AM
Is there someplace that sells pre manufctured side motor mounts for a 235? Planning to use an automatic, either a 350 or 700r4 and will need rear side motor . mounts
Joe
jremig #769228 08/07/2011 3:51 AM
I built some.
The story here.
Cletis #769243 08/07/2011 4:26 AM
Cletis, did you bolt those to the trans adapter plate?
jremig #769259 08/07/2011 5:14 AM
Yes, the plate I bought had the holes pre-drilled and tapped. It's the Buffalo adapter.
