0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#76848 04/28/2007 11:08 PM
Ok...seems everyone just wants to swap out the distributor with HEI. But that isn't happening soon.
Until the CD with the shop manual shows up...is this correct for my points?
"Point gap is .015 used, .019 new points"
I found it on a post about the 235, but prolly the same for a 292...right? This is a new set.
1965 Chevy C-30 1-Ton
"Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching."
#76849 04/28/2007 11:17 PM
Seems real close to being correct with a dwell angle of 28-32 degrees.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#76850 04/29/2007 12:24 AM
Well..new points are making a big differce. Pulling out the old...it had actually burned a spot on one side and was only making contact at a very small point.
Now I have set the timing with the 4 to the left of 0. Seems to have less surging in third there.
Please let me know if I am wrong somewhere. Thanks!
#76851 05/01/2007 9:39 AM
4 degrees advance is a good place to start.With the fuels the way they are today,I would advance the timing (counterclockwise)until it pings under a load then retard it until it just stops pinging.You will get better fuel mileage and performance.The 292 is a workhorse.
Wanted Good Woman:
