4 members (Otto Skorzeny, KEVINSKI, k2handyman, Stovebolt48), 127 guests, and 2 robots.
Topics128,034
Posts1,055,552
#76845 04/28/2007 6:26 PM
Junior Member
Junior Member
I'm trying to figure out what gears are in my 55 2nd. It looks like a stock rear end, but when I bought it, they told me it has 4.11 gears.
Pictures at www.novich.com/55Chevy/RearEnd/index.html
I jacked it up (both wheels) and spun one wheel. First, when I spin one wheel, the other goes in the opposite direction, and the driveline doesn't spin. After a little rocking motion with the wheel, I get the driveline to spin, and the other wheel doesn't move. One revolution of the wheel takes slightly under two revolutions of the driveline.
Do I double that to get about a 3.9 gear ratio? Was there a stock rear end with about that gearing?
My intent is to change the gears to get a little more speed on the highway, but I just haven't figured out what I'm working with.
Any info would be greatly appreciated.
#76846 04/28/2007 6:52 PM
Well if it's stock it'll be a 3.90 set. You could take off the rear plate and count the teeth on the ring and pinion to figure it out.
58' 3200 235 3-speed/OD
#76847 04/29/2007 10:03 PM
Jack up one wheel. Mark the driveshaft and the wheel. Make 2 complete revolutions with the wheel & count the turns on the driveshaft. It should be fairly close. The stock ratio as mentioned is 3:90, if it came with a factory overdrive it would be 4:11. Of course anything could have been changed over the last 50 years.
Fred
