2 members (rick46ia, Maybellene), 179 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
I have a 55.1
Anyone know where to get good US made parts for tie rod ends? You know...springs balls, etc.
Thanks - Scott
55 1st Chev.
Riding in the Passing Lane
Any of the specialty suppliers (American Classic) can supply them, although the country of manufactor may vary. What about changing to the new style?
1972 Chevy c10 Cheyenne Super
Scott,
Check your private messages.
Wrenchbender:
I am open to changing, but what are the benefits/negs of the change. I suppose if I don't change, I can replace the guts without affecting alignment?? What are the benefits the of the new stuff?
Thanks - Scott
55 1st Chev.
Lots of luck trying to find parts made in USA. I recently got a master cyliner (made in china) and a slave cylinder (made in Italy) from LMC, a very reputable supplier.
Benefits of the new-style tie rod ends are they are supposedly stiffer (they don't have the springs in them) and stronger. They say if you run radials with power steering you really need them. I'm running radials with the old style ends and the old worm box and don't notice any problems.
Probably the best way to go is to look at the balls. If they are out of round you might as well go with the later style. If they are good it will be a lot easier just to put a kit in them. You will still need to check the toe in after you put the kits in. You can do it yourself & adjust the toe in.
Anonymous
Unregistered
Anonymous
Unregistered
Quote
LMC don't make anything, only resales parts out of the book or what you can get yourself from GM (if you have a parts guy that will help you)
LMC has many of there own parts made for them. They have hundreds of old trucks in a warehouse that they take parts off of & have them reproduced.
see tech tip::
adjustable tie rod and associated bits wink
http://www.stovebolt.com/techtips/draglink_adjustable.html
Jim & Caroline
