1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#768326 08/03/2011 10:28 PM
Why wont my motor turn over? I have a brand new battery, 6 volt. ground from battery to frame, positive to starter post, motor has a ground to frame as well. I have 6volts at the stater post but it will not turn over. I have used this starter before and all worked fine.
Charlie
when was the last time it started,
Redryder pix
My Hotrod
joker #768346 08/03/2011 11:58 PM
The motor ran last than two months ago. I can turn it over by hand with the crank handle in the front.
It was an issue with the stomp starter! All is good now!
Charlie
