7 members (MickeyP, Barry Martak, Otto Skorzeny, kades51, Jon G, 1955 1 Series, 1 invisible), 116 guests, and 2 robots.
Topics128,088
Posts1,056,413
Members48,443
Working on my task force door to repair rust damage. I cut out a section of the inner door that had significant pitting and pin holes. The outer skin and lip look good with the exception of a dime sized area with pin holes. I welded up the pin holes. Would like to use a POR 15 or something similar to coat the inside of the skin before installing the inner patch. Will this hold up? Please advise.
I'm no expert but I'd say yes, should be fine. I brushed on epoxy primer nice and thick on the inside of mine.
Darren
ditto on that, but also make sure the drain holes are clear at the bottom - the reason the doors rust in the first place is those drains get plugged with dirt and then water getting in around the window turns it to corrosive sludge
Thanks for the response. I have a little work left to do to fill those pin holes. Shined a light and could see some tiny holes. Also, raising that pinched lip is a bugger.
This little jewel here will help to open up the flange.
http://i5.photobucket.com/albums/y1...20Restoration%20Album%202/Picture585.jpg
I find that once the jaws on Vice grips start to wear, they make an excellent starting point for specialized tools.
http://i5.photobucket.com/albums/y1...20Restoration%20Album%202/Picture586.jpg
http://i5.photobucket.com/albums/y1...20Restoration%20Album%202/Picture587.jpg
Making these and where I used them can be seen here....
55 Chevy Wagon Tailgate Repair
Speaking of metal repair and southern md. Maybe I should come by for a consultation. And maybe I should bring by my tailgate (62 C-10)? California MD.
Welcome to Stovebolt.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
